• RealmsWiki.com
Go Back   HeroClix Realms > HCRealms.com : General > News, Articles & Original Content
Reload this Page Marvel HeroClix Mutant Mayhem New Game Mechanic Article: Feats!
Page 1 of 19 1 234511 > Last »
Old 09/15/2004, 11:50
Rep: 91240 | 919       #1
BrotherMagneto
Groo Advocate
BrotherMagneto's Avatar
Sep 2003
Marvel HeroClix: Mutant Mayhem New Game Mechanics: Feats by Jason Mical
Arguably the game mechanic that has sparked the most interest in Mutant Mayhem are the addition of Feats, a kind of card unique to the HeroClix game. And rightfully so: Feats are an extremely flexible upgrade to the game and, in the right hands, can take a "theme team" to ultra-competitive status. Ready? OK, here we go.
From the rules:
Feats reflect special training or other abilities that characters have. They are printed on cards, which describe how the feat is used, which character may use it, how much the feat costs to add to your force, any modifiers the feat provides to character abilities, and any prerequisites the feat has for use. Any character may use a feat as long as it meets the feat's prerequisites. If a prerequisite is a team ability, that team ability must be printed on the character's base; wild card team abilities, which mimic other team abilities, do not count. If a prerequisite is a power, that power must be showing on a character's combat dial in order for the character to use the feat.
Each feat also has a cost that is included in the cost of your force; you may play with as many feats as you like. Before placing characters, each player reveals his or her feats and places them off to the side of the battlefield. Multiple copies of the same feat are not cumulative, but if one copy is removed from the game, another copy in play may be used.
All feats are optional. Feats that modify a character's combat values apply only while the character is using the feat unless the card text says otherwise. Feats part of a player's force may target only characters friendly to that player.
Some feats say "Choose a character." This assignment must be made when a player builds his or her force, and the feat applies only to that character during the game. After the map is chosen and players choose their starting areas, but before players place their characters, you must declare such choices to all players; you may not change the choice later. In some cases, an assigned character may not be able to use the feat when the game begins because it will not meet the feat's prerequisite(s) until it has taken damage. If an assigned character is KOd, remove its corresponding feat(s) from the game. Each feat removed from the game is worth a number of victory points equal to its point value to the player who KOd the assigned character. If a player's entire force is KOd, any feat cards in that force that do not require assignment to a character or characters are worth a number of victory points equal to their point value to the player who KOd the last figure of that force. If a feat card does not require assignment to a character or characters, then only one copy of that feat card may be used as part of a force.
Feat text supercedes the HeroClix rules.
Analysis
At first glance, that may seem confusing, but let's look at a couple of feats and see exactly how those feats are used in game situations.
Three powerful feats, and so many ways to use them! No matter your play style - if you're fond of fielding the Fantastic Four no matter the odds, or if you're the most ruthless player for three counties, there's something to love in the feat cards. Remember, in a tournament you cannot swap out your feat cards between matches, so chose wisely!
When WizKids first announced "feat" cards, the two words that sprang to every True Believer's lips were "Fastball Special!" And there it is, in all its glory. Fastball Special is a pretty specific feat: more than any other in Mutant Mayhem, it relies a lot on team structure, and can be removed if one of the two participating characters leaves the game. This is somewhat reflected in its point cost; although it allows a single devastating attack, it costs little more than what players often have left over when building their forces. Although you can certainly perform Fastball Special with Colossus and Wolverine, you'll note that it is fairly flexible, allowing even for Giant figures to get in on the action. The attack and damage adjustments at the top of the card apply to when the feat is actually used; so after Piotr tosses Logan, Piotr's attack value goes up by 2 and Logan's damage dealt increases by 1.
Once you've used a Fastball Special, it's removed from the game and you cannot use it again unless you have a second Fastball Special card lying around. The good news is, since Fastball Special cost you 12 points to use, you've just secured 12 points towards your survivors; your opponent cannot get those points by KOing either character assigned to the Fastball Special. Before you go stacking 10 Fastball Specials on a Colossus and a Wolvie in a single event, beware: your opponent will wipe at least one of those characters out as soon as she realizes what you're doing, and then you lose all of the unused Fastball Specials - and those points do count towards your opponent's victory points.
Rip it Up is another fantastic feat, and the picture doesn't feature the ever-lovin' blue-eyed Thing for no good reason. This card was practically custom-made for Ben Grimm and buddies with similar powers. And yes, you read it correctly: every time a character with Super Strength moves, that character "rips it up" and grabs a chunk of terrain to use as a light object. Notice that it doesn't require you to choose a character, either, so you could conceivably build an entire team based on the premise of Super Strength and free light objects. It's fairly pricey as feats go - 20 points - but having an endless supply of light objects is worth every one. When combined with Charge, Rip it Up is a menace to turtlers everywhere.
Finally, Trick Shot. Hawkeye's Fan Club might be drooling, but those of you with a keen eye have noted the other optional prerequisite of Plasticity and are currently doing a little math. Trick Shot is another fairly expensive feat, but it is worth its weight in gold - or victory points. Although there aren't a lot of characters sporting Plasticity out there, the characters that are out there benefit so greatly from Trick Shot that laughing about it will only make it worse. But then there's the crew with Ranged Combat Expert. Aren't you glad you can send Wolvie in, claws bared, and follow up with Colossus tearing the ground to shreds? So are we.
That wraps up the New Game Mechanics for Mutant Mayhem. Tune in next week for a pleasant surprise, and after that, figure previews!
BrotherMagneto
Visit BrotherMagneto's homepage!
Find More Posts by BrotherMagneto
Rep: 5040 | 59       #2
Funky Jett
Funky Jett's Avatar
May 2002
Holy CR@P!!!
In my day, we didn't have Heroclix. If you were being attacked by Superman with a 3d dumpster, you just had to hope you could outrun him.
Funky Jett
Visit Funky Jett's homepage!
Find More Posts by Funky Jett
Old 09/15/2004, 11:53
Rep: 13863 | 146       #3
drgnoftyr
Mar 2003
nice i'm real excited for fastball special and rip it up .... here's hoping the rest are as good!!!!
"He's got a possible 12 Attack",
Yeah, with 3 Perplex stacked on top of his 9 Attack!?
Why not advertise all figures with stats that are 3 higher than what they've got?
WKids could say, "This Paramedic does 3 Damage".
drgnoftyr
Visit drgnoftyr's homepage!
Find More Posts by drgnoftyr
Old 09/15/2004, 11:55
Rep: 10 | 8       #4
Heroclix1234
Heroclix1234's Avatar
Oct 2002
Quote
Originally posted by Funky Jett
Holy CR@P!!!
Seriously...how can you post the minute it comes out?
Heroclix1234
Find More Posts by Heroclix1234
Old 09/15/2004, 11:57
Rep: 12045 | 128       #5
bam
bam's Avatar
Feb 2003
Feats will improve gameplay
To the folks at wizkids, thanks for the this addition. I can't wait to use an FF team that has a chance to win.
BAM
bam
Find More Posts by bam
Old 09/15/2004, 11:58
Rep: 156904 | 1578       #6
Darth Sabre
Darth Sabre's Avatar
Aug 2002
Pretty sweet. These should add some real flavor to the games, once we see how they are incorporated into the game.
Clixers for Comic-Accurate Theme Play Group
COIE Scenario! Click Here!
Darth Sabre
Find More Posts by Darth Sabre
Old 09/15/2004, 11:59
Rep: 12045 | 128       #7
bam
bam's Avatar
Feb 2003
Reed Richards + trick shot = stealth hunter.
They say the best weapon is one you never have to fire. I respectfully disagree. I prefer the weapon you only have to fire once. That's how Dad did it, that's how America does it, and it's worked out pretty well so far." Robert Downey/Tony Stark
bam
Old 09/15/2004, 12:01
Rep: 29812 | 307       #8
MeatLoafX
MeatLoafX's Avatar
Aug 2002
Sounds cool.
Our local games normally don't play survivor points, so we'll have to incorporate some new house rules to deal with the points from feats like Fastball special.
The Rip it Up sounds awesome. Free light objects for a character!
Oh, I'm picking out a thermos for you...
Hawkeye Game Club
"These young 'uns gotta learn, you just don't mess with no mean-eyed furballs!" -- Ch'p
MeatLoafX
Visit MeatLoafX's homepage!
Find More Posts by MeatLoafX
Old 09/15/2004, 12:02
Rep: 370 | 12       #9
dino1626
May 2002
This will be cool.I'm really pumped for MM.
My good trader list http://www.hcrealms.com/forum/showth...traders thread
What-Me worry?
dino1626
Find More Posts by dino1626
Old 09/15/2004, 12:05
Rep: 80935 | 818       #10
thjimmy
and if you can find them
thjimmy's Avatar
Jul 2002
Way to add another fun twist to the game!
Can hardly wait for Mutant Mayhem.
Are you the best player in the Midwest? Prove it on 9/18/10!
6 Principles for introducing new players to Heroclix!
2008 North American Championship Fellowship winner
DC World Champion
thjimmy
Find More Posts by thjimmy
Old 09/15/2004, 12:06
Rep: 535 | 13       #11
vaders sabre
vaders sabre's Avatar
Aug 2003
Cool!
Oh thank GOD Darth sabre your here...No wait get him!
vaders sabre
Find More Posts by vaders sabre
Old 09/15/2004, 12:10
Rep: 5040 | 59       #12
Funky Jett
Funky Jett's Avatar
May 2002
Quote
I could tell you, but I'd have to Fastball Special you! (Actually, I have no life, so I can watch for new posts all day long)
I think it's great that once the Feat is removed (after you pull it off), you get to keep the points.
Funky Jett
Rep: 10 | 7       #13
BoosterGold
BoosterGold's Avatar
Jan 2004
If Wolverine is thrown as part of the fastball special, can he use BCF? All it says is the 2nd character deals the damage and add 1 to damage dealt.
Good Trader Thread:
http://www.hcrealms.com/forum/showth...ht=Boostergold
BoosterGold
Find More Posts by BoosterGold
Old 09/15/2004, 12:11
Rep: 10 | 7       #14
VorpalDiplomat
Aug 2004
This is awesome!!!!!
VorpalDiplomat
Find More Posts by VorpalDiplomat
Old 09/15/2004, 12:12
Rep: 5421 | 62       #15
dal_johnson
Judge
dal_johnson's Avatar
Dec 2002
They look great. One small questions though. Fastball Special says that you remove it from the game once it is used.
For Rip it up and Trick shot do you get to keep using the card repeatedly or is still only use it once? So say I make a super-strength team. Can I have one "rip it up" card and have all my figures getting light objects repeatedly?
Current Trade List
http://www.hcrealms.com/forum/showthread.php?t=279276
dal_johnson
Find More Posts by dal_johnson
Similar Threads
Thread Thread Starter Forum Replies Last Post
DC HeroClix Legacy New Game Mechanic Article: Team Abilities! BrotherMagneto News, Articles & Original Content 285 02/16/2005 23:19
HeroClix Review – “Mutant Mayhem” Marquee Primer. Pt 3: Feats, Battlefields, & Bystan AZS HeroClix General Discussion 17 12/08/2004 03:47
Marvel HeroClix: Mutant Mayhem! BrotherMagneto News, Articles & Original Content 369 11/01/2004 14:37
Marvel HeroClix Mutant Mayhem Draddog News, Articles & Original Content 264 09/28/2004 20:57
Marvel HeroClix: Ultimates New Game Mechanic - New Team Abilities Draddog News, Articles & Original Content 270 05/06/2004 13:59
[IMG] code is On
HTML code is On
Contact Us - HCRealms: The Premier HeroClix Gaming Community - Archive - Privacy Statement - Top
Copyright ©2000 - 2008, RealmWorx
All Rights Reserved.
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
